Drawing with Pattern
jeph_s22
jeph_s22
Hello everyone. I need some help on this part. I am trying to draw a pulley.  What is the best way to do this without having to draw each tooth separate? I was thinking with a Rectangular Pattern, but if I do that my drawing is unconstrained. Any help is appreciated.
Part also attached, what I have done so far.
jhackney1972
If you constrain the original sketch, before you pattern it, the pattern will be constained also.  I took a short cut, since your tooth profile was not constrained, and used a Fix constrain on the tooth profile.
John Hackney, Retired
jeph_s22
Thanks for your help.
