I have been attempting to learn how and model this lightning bolt and it is driving me mad
I would really appreciate some help in learning to do it cuz I have tried to create by sculpting a face and extruding, by using a triangle and a path to sweep it, sketching and extruding just made it square ughhhhhh
it seems so simple but it is driving me crazy I just have to learn how please help
you can google the lightning bolt name and find the image if need be
I attached the picture I use as a canvasmy kryptonite
Solved by davebYYPCU. Go to Solution.
Can you work it out now from my timeline?
Loft with joins....
Might help...
It looks great is there any way for me to get the model in my fusion 360 to deconstruct the process
Loft with joins....
Might help...
I really appreciate it I will let you know if I can figure it out from that
thank you thank you
that was indeed helpful I didn't even consider looking at the design that way
also I didn't know you could loft from a face to a point
can you loft from a face to a line? just curious if so how
Nope, Point is sort of unique, if not a point I think it has to be a profile, solid or surfaces.
Surfaces will take two lines, but not a profile and a line.
Pleased you got it...
