Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Mirror Body Error
3 REPLIES 3
doleksa
220 Views, 3 Replies
Mirror Body Error
The part I am building has multiple bodies and I am trying to mirror them around a construction plane.  All the bodies mirror except 1 of them.  I get an error that compute failed with no other information.  Below is a screen shot of all the bodies in the part.
Body 65 is the where I get the error when I mirror it around the construction plane.
Any ideas on what could be the problem and how to correct it?  I have attached a copy of the file below.  Any help will be much appreciated.  Thanks.
3 REPLIES 3
aliobidi
in reply to: doleksa
Hi ,
just make the body as component and mirror the component
for make sure I just copy the component  and "paste new "
your file below
see the time line and ask me if you have a question
TrippyLighting
Can you elaborate on what the purpose of the design is and what you want to do with the end result?
If this is a game design or, maybe a small display or toy model I'd guess precision isn't of the utmost importance and I'd recommend one way.
On the other hand, if this were a mechanical design for manufacturing purposes I'd start completely from scratch!
The reason this happens is your imprecise modeling workflow. Way too many sketches and I'd guess 98+% of them aren't properly dimensioned or constrained.
doleksa
in reply to: aliobidi
Awesome! Thanks so much!
Technology Administrators
