Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Joints and Assemblies
15 REPLIES 15
Message 1 of 16
Drewpan
647 Views, 15 Replies
Hi All,
Quick advice on where Joints should fit into the Fusion Workflow.
Should I be putting Joints into the Top Level of my Model or with each Assembly?
I did a slightly more complicated Model recently and added Joints to individual Assemblies and then joined
each Assembly after to the Model. When I had a few minor issues I just had a bit of trouble "finding" some of
the Joints. Is there a Standard way to do this?
Picture supplied for @TheCADWhisperer
(Model is quite cool and really good practice draw)
Cheers
Andrew
15 REPLIES 15
Message 2 of 16
TheCADWhisperer
in reply to: Drewpan
@Drewpan
No file Attached to diagnose?
Why are there multiple bodies in same 3D space?
I would place “joints” at the same level that they are in the real world.
Example: When I rebuild a car, the “joints” for the alternator sub-assembly exist in that assembly.  The joints mounting the alternator might be at the engine assembly level or at the top level car assembly level.
Message 3 of 16
Drewpan
in reply to: TheCADWhisperer
I thought that was probably the case. I created the Wheel Sub-assembly with the Crank and Counterweight and
then Joined them at the Top Assembly. It got a bit confusing at times when there were Parts like the Steam
Pipe joining the Boiler and the Piston Assembly and exactly where I put that Joint.
No File because I have actually finished that one. The Picture was in lieu of a File because it showed what I
meant with Joints in different places.
Thought I had a lot of this worked out but what do YOU mean by "Why are there multiple bodies in same 3D space?"
The Picture is the finished Model with all of the Assemblies and Sub-assemblies. I am not quite sure what I did
wrong here.
Cheers
Andrew
Message 4 of 16
TheCADWhisperer
I am not quite sure what I did wrong here.
@Drewpan
No file Attached to illustrate?
Message 5 of 16
laughingcreek
Message 6 of 16
Drewpan
in reply to: laughingcreek
Ok, I think I know what you mean now. I am not sure what that is or why it happens.
The Parts and Assemblies as joined don't overlap AFAIK. In the design there is empty space behind that piece
of sheet metal. I didn't think it necessary to check for interferences and now that I have there are no game
killers I can see except for a couple of Hex Nuts and simple stuff. There is nothing that should interfere unless
it treats the round Boiler like a square box and that overlaps. In which case how do I fix that or need to fix it?
Nobody has pointed this out before so it obviously wasn't a Problem I knew about.
Andrew
Message 7 of 16
davebYYPCU
Another way to put it, - 2 bodies in the same space,
One is a sheet metal, and the other a solid body, one eyeball turned on at a time,
Not reviewed the file on how it was done, but I suggest you Remove this one.
Might help.....
Message 8 of 16
Drewpan
in reply to: davebYYPCU
Think I remember how that happened. Now I know what it is.
Cheers
Andrew
Message 9 of 16
TheCADWhisperer
@Drewpan
Tip:  The tap-drill size of an M5 threaded hole is not 5mm.  I have seen this cause designers a lot of grief if not understood.
Tip: You can add the thread feature to the hole feature.
Message 10 of 16
TheCADWhisperer
@Drewpan
Message 11 of 16
TheCADWhisperer
@Drewpan
Axis of Spring is not constrained.
Tip: Because it is not easy to have a spring compress in Fusion - set one end to "disappear" into solid.
Message 12 of 16
TheCADWhisperer
@Drewpan
I doubt whether 1mm material thickness will hold up for very long...
Might even be difficult to machine - depending on the process - without blowing out the thin web.
Message 13 of 16
TheCADWhisperer
@Drewpan
Major interference - both ends...
Tip: For moving parts there must be clearance between the components for two reasons.
1. We cannot manufacture perfect parts.
2. Friction
So for a slot of 3mm the mating part must be less than 3mm (or other way around).  Must be clearance.
Message 14 of 16
TheCADWhisperer
@Drewpan
Message 15 of 16
TheCADWhisperer
@Drewpan
Imagine the friction between these components - even if we could manufacture "prefect" cylinders.
This cannot be assembled because of friction (without press fitting).
And if it didn't seize up immediately it would certainly heat up fast...
Same with all moving joints...
Imagine that we have two armies.
We'll call them the Red Atoms and the Blue Atoms.
Let's say the Blue Atoms occupy a circle of 24mm.
As the Red Atoms approach the Blue Atoms and attempt to occupy the same Ø24 space - somebodies Atom army has to move - they cannot occupy the same space.
Message 16 of 16
Drewpan
@TheCADWhisperer
Thank you for the analysis. I should have taken more care with my drawing which was from a Plan from a magazine
on the Internet. I did not check the measurements and make allowances for things like clearances. I also made a
few small changes that created some problems - like making the Beam wider because I wanted pockets to make
it look nicer. A lot of the drawing was straight numbers from the Plans, not thinking.
Right now I am trying to do lots of drawing to get my head around the software and increase my speed. I should
be thinking like an engineer as I do it however. I need to take into account clearances and tolerances and model
them accordingly.
I do appreciate your time and effort to help me achieve all of this.
Regards
Andrew
Technology Administrators
