Is there a command option to flip/invert a surface/face in Fusion 360?
5 REPLIES 5
7471 Views, 5 Replies
Hi everyone, is there a command that can flip or invert a surface's direction ( that's what they call it in Rhino, anyways).  I don't mean the Mirror Command either, not that kind of "Flip".  Basically I got some geometry that was imported from Rhino into Fusion 360 and some of the surfaces are "Inside-Out'....and I was hoping someone knew a command in Fusion 360 that can flip/invert the surfaces.  Btw ive had this happen with Fusion 360 geometry as well, like the in the Patch Workspace... the gold side of a surface (the back) will be on the wrong side, etc, etc.  Hoping you folks know a solution, thx.
5 REPLIES 5
davebYYPCU
Patch > Modify > Reverse Normal
Might help....
in reply to: davebYYPCU
  1. That'll work, thx.
chrisplyler
Very odd that you selected your own reply as the thread Solution, instead of @davebYYPCU's reply that contained the actual solution.
BenzyMH
Simple forward straight answer ! thank you
My System Info
Manufacturer Hewlett-Packard
Model HP Z800 Workstation
Total amount of system memory 24.0 GB RAM
System type 64-bit operating system
Number of processor cores 6
My Graphic Card Info
Display adapter type NVIDIA Quadro 2000
Total available graphics memory 13047 MB
Dedicated graphics memory 1024 MB
Dedicated system memory 0 MB
Shared system memory 12023 MB
Display adapter driver version 9.18.13.2078
Primary monitor resolution 1920x1080
Secondary monitor resolution 1920x1080
DirectX version DirectX 10
Thanks, helped a lot !
Technology Administrators
