- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I insert a component using "Insert Derive", Fusion usually adds the component to the Window and the Browser. When inserting more than one component from different files, only the first gets added to the Window and Browser. All consecutive derives are "ghost" components. You can select them via the History, but only the blue shadow of the component appears. "Find in Browser" and "Find in Window" in the History menu do not work. If I close and re-open the file before inserting a second component it works as expected.
I can recreate the bug in new designs when inserting screws from my library, but I could not recreate it using arbitrary shapes.
My screw library uses threads (not modeled) and a few user parameter describing the geometry.
The screenshot show a "ghost" screw in the Window. The joints are not necessary to recreate the bug.
The file is available here: https://a360.co/2FzUtOQ
The second screw does not show up in the online preview, but after downloading the Fusion Archive and importing it it is visible again in the history, but nowhere else.
Tyler Henderson
