How to slice an object with a 3D sketch
anya.zinn
Message 1 of 12
anya.zinn
Hi everyone,
I'm trying to draw up quite an organic shape on Fusion 360 (as seen above).
I'm struggling with how to make it.Right now I've drawn two splines on a lofted cylinder which form the 'outline' of the shape. But now I'm not sure how to delete the parts of the lofted form that fall out of the sketchs' outline.
Any suggestions on how to move forward? Or any other approaches?
Thanks.
Replies (11)
Message 2 of 12
jeevesme
Have you tried a sweep using profiles and guide rails?  Can you post the file?
_________________________________________________________________________________________________________________________________________Forever yours,
Love,
Brian
PS. If this answered your question, please mark as answered so others do not read through the posts trying to figure out if it was answered.
Message 3 of 12
SaeedHamza
This can differ from one design to another, according to the shape you want to split
Please share the file with the cutting sketch to show you how
Regards
Saeed Hamza
Message 4 of 12
anya.zinn
Hello everyone,
Thanks for your replies. Attached is a STEP and DXF file. Let me know if
this works.
Message 5 of 12
anya.zinn
Hi Saeed!
Thanks for your reply. Attached is a STEP file. Let me know if it works?
I tried some sweeps but it was tedious and inaccurate, and I'm unable to thicken the structure beyond 25mm (didn't use guide rails though, so will explore that option today). I've also attached that file as 16 OCT...
Thanks for your help !!!
Message 6 of 12
etfrench
It would be better if you can export the native Fusion 360 file.  From the File menu, select Export, then choose Archive (*.f3d) and attach the output file to your post.
ETFrench
Message 7 of 12
anya.zinn
Thank you for the suggestion!
Attached are the f3d files.
Kind regards,
Anya
Message 8 of 12
anya.zinn
Hi Saeed,
Sorry to bother you again, but I've attached the f3d files to the comment below.
Thanks again for your help.
Anya
Message 9 of 12
jeff_strater
Don't mean to butt in here, but looking at that original picture of the object, I would not try to model this in a BRep environment (solid or surface).  Have you considered using TSplines (Sculpt workspace)?  Since this shape is so "organic", it seems like it might be a better toolset to use.
Do others agree or disagree?
Jeff Strater
Engineering Director
Message 10 of 12
SaeedHamza
@jeff_strater
You're right. Creating this using Patch or Model environments is not an option, This is clearly a job for the sculpt environment!
@anya.zinn
Now creating it in the sculpt workspace can be done in many different ways, but it will require some analyzing before that to decide the best approach possible, so look at your body carefully from different angles and decide how to get the closest shape to it, and maybe apply some editing for it later on to get even closer until you achieve it
My guess is that you can start with a sweep and then edit it according to an attached canvas, or you can use a loft by creating an over all path and use a plane along path to create the profiles of the loft along it. This might get you closer than the sweep, but be careful not to get the self intersection warnings
So feel free to ask questions along the way whenever you feel you're stuck at a certain point
Best of luck
Saeed Hamza
Message 11 of 12
laughingcreek
Here's one approach using tsplines.  model it as an outside shape, and an inside negative shape.
Message 12 of 12
anya.zinn
2 years late but THANK YOU for showing me in 8 minutes what took me close to a month Cat LOL
I ended up doing a whole lot of sweeping and lofting wizardry. But this would've been far better.
Thanks again!
