In AutoCAD you can simply substitute whatever value you want for the actual dimension, I would like to do this with Fusion 360, but can't find out how to?
Example; a rod is 21" long in the model, and the drawing dimension is showing 21, but you want to override and show 20?
I understand how to change the model and update the dimension, but I don't want to do this, I just simply want to override it like you are able to do in AutoCAD.
Thanks.
Solved by ClintBrown3D. Go to Solution.
Solved by MingweiGao. Go to Solution.
After placed the dimension, double-click on the dimension to edit it, then delete the original dimension and input the new value.
As @MingweiGao says, double-click then edit, like this:
Thanks, for some reason I have having an issue doing that, but after a restart it is now working reasonably well.
