Hi, I am currently using Fusion 360 and do enjoy the software. Nonetheless, I have a question related to the tools that can be used. I have two components that are assembled (virtually) such that the two respective faces are touching each other (as per screenshot). Is there any way to determine, using Fusion 360, the total contact area between the two pieces? Thanks, FZ
Solved by TheCADWhisperer. Go to Solution.
Attached is the assembly file of two bodies illustrating the problem.
@Anonymous wrote:Would I be able to
use the same methodfor more complex geometries too?
There is always a way...
...trimmed surface comes to mind...
