How to change title block to different title block???
mrm1018
mrm1018
I have some older drawings that were created with the base fusion title blocks.  I would like to edit these drawings to use a new title block I've created in a different drawing.  How is this done?
g-andresen
Hi Mike,
1. create new template with your titleblock > save as ...(folder: titleblocks)
2.open existing drawing
3. rightclick sheetsymbol > add sheet
4. browse and select your new template
5. select 1. drawing > sheet settings > titleblock > select yours
6. Drawing 1 shows the new titleblock.
günther
mrm1018
Thank you Guenther!  That’s slightly convoluted and not intuitive (hardly your problem), but it gets me what I need!
The fusion team still has a long ways to go on the drawing side of things.
