Is there any way to look at your sketch face? Hopefully from the cube..?
Solved by jeff_strater. Go to Solution.
Hi Luke
the best way is to select from the root the sketch and look at
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
While you are editing a sketch, the "Look At" button in the sketch panel will do a "Look At" of the active sketch.
You can also do this with an Action/Object workflow:
click on this icon, then select on any profile (shaded area) in a sketch, and Fusion will look at that sketch:
Jeff Strater
