how do I Rotate the numbers on clock face.
HuntleyBill
HuntleyBill
I would like to  rotate the numbers on this clock face so that they look like the clock,jpg attached. I have the clock face made up, I just can't figure out how to rotate the numbers from their current position without messing up the alignment.
Can you teach me how to do this?
Thank you
Bill
davebYYPCU
I picked the text box centre point to be the anchor point.
Circular pattern the radial centre lines for the text.
Make one text box, with a value.  (12 in this case)
Sketch Copy the Text.
Paste another 11 of them with Point to Point.
Edit the 11 duplicates and change the text value.
Why is none of the clock on the Origin?
Your text articles are missing, but the Extrude is not in Error - weird.
Might help....
HuntleyBill
That worked. Thank you so much.
