How do I cut out an offset prism?
jwatte
jwatte
I have a part, cut out of a rectangular block, where the bottom of the cut-out is not a horizontal plane (the bottom has slight drafts.)
Now, I want to make the "actual bottom" be 1.5mm thick along the Z axis (which is not 90 degrees to the draft -- more like 75 degrees.)
In a tool like 3ds Max, I would select the faces, then offset then along the Z axis to create a new prismatic feature, and then use CSG to cut out from underneath these surfaces. However, I can't figure out how to do this with the primitives available in Fusion, mainly because there doesn't seem to be a way to first construct a derived body, and then use that body to cut out from the original body.
How would I best accomplish what I want here? (In this screen shot, the floor of the carve-out is visible; I have also projected the faces of that floor to the bottom of the rectangular stock part, for illustration. I want the floor to be 1.5mm thick in the Z direction.)
HughesTooling
Try going to the patch workspace and use Offset face set to zero offset to make copies on the faces. Move the faces down the required distance. Still in the patch workspace build sides and a base, stick the faces to make a solid then switch back to the solid workspace and use combine set to Cut.
You can create a copy of a body using Boundary Fill by the way.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Question, why can you just offset the faces, moving them down 1.5mm will create a variable wall thickness depending on the angle\curve of each face.
Mark
Mark Hughes
jwatte
I understand that the "true thickness" of the bottom will vary based on angle.
The "1.5 mm projected down" works better for my machining solution, and because all the faces are < 15 degree canted, the actual difference is small.
Separately: Thanks for the suggestion to check out "patch space" and also "combine" -- hopefully I can make something work along those lines!
chrisplyler
Another thing to consider:
Learn how to model this parametrically instead of using F360's crappy Primitive bodies.
The main thing I was missing was Modify -> Combine -> Cut.
Type a product name
