Hi
I have already posted this, but I really need someone to be really specific on how to convert components to Sheet Metal and then select Flat Pattern to allow me to create a flat DXF, all from a rolled surface.
I have attached a fusion file that has R2D2 skins. This is for a 1:1 scale project. The skins are eventually made in 1mm aluminium and rolled, but I need a flat version of the Outer and Inner Front and Back skins to give to a laser cutter.
It has already been suggested that the above way can do this, but I cannot find how to convert the skins to sheet metal or how to find flat pattern options. I can find flatten in sculpt but I don't think that is the right thing?
The original file was an iges and I don't think it was made that well, which I think doesn't help.
What I would really appreciate is a screencast of the method if anyone has time to do one for me to show me how to do this work.
I can provide the original iges if needed.
I really appreciate any help that may be forth coming.
Kind Regards
Ian
