Group together bodies as component for animation
Hi, I just started learning Fusion 360. How do I group together several bodies so that they function as one component for animation?
Here in design view I have selected the rotor blades and the rotor head
I used Create Components from Bodies
Instead of being grouped together as one component, each body is its own component
How do I group together so all of these behave as one component instead?
jeff_strater
Yes, that is the way that Create Component From Body works - that was the most common workflow.  If you want to put multiple bodies into one component, just create the component from one of the bodies, then drag the rest of the bodies into that component in the browser:
Jeff Strater
Engineering Director
