export model as a vectorfile to vcarve pro
potlsnekkeri
potlsnekkeri
Hello
i need to export this model so i can load it up into vcarev pro and cut this part out in size as it is ,same scale?
how can i eport this from fusion 360 ?
https://a360.co/3dScN7n
g-andresen
project the object into a sketch, save it as DXF (right click > save as DXF)and import it into V-Carve to create the desired toolpaths.
günther
potlsnekkeri
thanks
how can i project the object into a sketch
g-andresen
@potlsnekkeri  schrieb:
thanks
1. create a sketch on the top surface
2. CREATE > Project (shortcut P) > select the body
3. finish sketch
4. Browser > rightclick  sketch > save as DXF
günther
Leo_Dyn
Not in front of Fusion right now, but if I recall correctly, don't you need to click on the "bodies" option within the project dialog box, where normally the "entities" option would be selected? Of course that all depends on what you are trying to project. I think some things work fine with either option, but there are cases where that option is necessary.
g-andresen
Easier in this case is of course the Entities option (because of the pockets).
günther
Warmingup1953
Create a new Sketch selecting the face of the Solid Body as the Plane..Screenshot 2022-08-27 143952.jpg
Then type "P" for Project and select the geometry needed and hit "Enter" ...This Geometry (2D) is now in the Sketch and you can Right click in the Tree and Save as .dxf.
