Duplicating or copying components
Dear Fusion 360 Community,
I would like to know whether there is a way to duplicate a component in Fusion 360 without maintaining its relationship to the original component?
Currently, when I copy and past a component, the components receiving the naming convention "Comp: 1" and "Comp: 2". Whenever I make changes to "Comp: 2" (e.g. applying a new texture, or deleting an edge), these changes are applied to the original "Comp: 1" as well. How would I avoid this?
My only current option is to paste the bodies to the top-level design and to create a new component from these. However, this does not allow me to copy things like decals to the new model.
Many thanks in advance,
-Ollie
haughec
Hi Ollie,
There is a "Paste New" option that allows you to paste independent copies of copied components, though it currently pastes them as a Base Feature (you'll lose any feature history associated with the component).  The best way to create an independent component presently is to save a copy of the component using Save Copy As (available from the right-click menu when a component is selected), and then insert that component back into your design (available from the right-click menu when a design is selected in the Data Panel).
Hope this helps.
Charles
Charles Haughey
Fusion 360 User Experience Architect
The "Paste New" option does indeed copy all design history for that new component, but unfortunately loses the history of the component you copied. See the following post for an example of this behaivior.
http://forums.autodesk.com/t5/sketching-sculpting-modeling-and/disappearing-history/td-p/5420288
OFGLLC
Kudoed you on this solution but when I went to try the Save-Copy, then locate the copy to Insert into the current Design, I can't see it. (empty folder that I put it into)  I know it's there because when I attempt to save-copy it again, I get a replace option.  What am I doing wrong?  Thanks for your consideration
Update:  Never mind, rookie error.  Saved it to a local drive, looked on cloud.  Worked great.
OFGLLC
Last comment.  The second method, apparently like the first does NOT bring the timeline history with it.
Jools-Taylor
Sorry to ressurect this but once you have imported it you need to then expand in the browser section by clicking the arrow then right click and break link. That imports the design history
