Good Morning. I have put together the sheet below to the best of my abilities being fairly new to fusion.
I have the need to add some line work to augment some of the information shown and some hatching. Doesn't really make sense to model.
For example, I would like to draw and GROUND PLANE line on the top views to show the assembly sits of the ground.
I want this to be hatched in accordant to our architectural standards. (yes I am using Fusion for architectural shop drawings).
The other thing I noticed is that when the sheet is exported to a DWG and it is opened in Auocad, all the elements are drawn in paper space and I am unable to edit them or interact with them in a anyway. I would like to know how to get them into model space so that I can import them into other CAD applications (Revit in this particular case).
Thank you in advance.
