Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Dark mode
177 REPLIES 177
Message 1 of 178
166085 Views, 177 Replies
Dark mode
Hi! Are you expecting to put a dark mode option for fusion 360? The ligh color from the UI hurts my eyes and make to much notority from screen!
Tags (1)
177 REPLIES 177
Message 21 of 178
alan
in reply to: nvampilogov
Me too!!  Visually impared and dark mode really helps.
Message 22 of 178
kieranbarker95
in reply to: alan
Here to bump the thread.
Dark mode would be very important to me (and clearly many other users of f360). I work primarily at night (with fusion 360 being my most used program) and having a high brightness hdr monitor means I need to turn down the brightness every time I enter fusion in order to avoid having my CAD model permanently burned into my retina. This is something that is a pain and could all be easily avoided by having a dark mode!
In fact, to prove how easy a dark mode would be to implement, I photoshopped one in 5 minutes!
Message 23 of 178
in reply to: kieranbarker95
I went through the folders looking for a file that would change the background color of the UI but had no luck. Would't it be possible to do it manually? i did that before in other programs by just editing a file with notepad++ or photoshop
Message 24 of 178
gaylord.giret
+1 dark mode too
Message 25 of 178
whizbanger
in reply to: gaylord.giret
+1, it would be a great improvement!
Daren
Message 26 of 178
bogdan.dumitru
in reply to: whizbanger
Bump!
We need dark mode!
And before you ask, I already turned down the brightness level on my monitor to 0 (ZERO) and it's still way too bright for night work (I have another day job).
HELP!
Message 27 of 178
+1 for dark mode
a must have feature
Message 28 of 178
neljoshua
Please add a dark mode!
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Message 29 of 178
cnguyen6Q2HH
in reply to: neljoshua
I agree. We have a dark mode on every application we touch nowadays. Everyone in the office loves the new dark theme for Inventor 2021. Please add it to F360 as well!
Message 30 of 178
danboarder
If someone can find the theme files that we can edit, please post and let us all know!  My MacOS is entirely dark mode, except for Fusion 360 (and this website, which I can force-adapt using extensions), looking forward to getting Dark Mode going!
Message 31 of 178
drew.regner
Thanks for the Idea to look for the Chrome Extension, I never even thought of using that, for websites, I just lived with the normal color.  I also am in favor of having a dark mode for Fusion.
Message 32 of 178
+1 for dark mode
Message 33 of 178
gearshredder
+1 dark theme. No just changing the environment but the window elements.
Message 34 of 178
Would love to have a Dark Mode in Fusion 360 too!
Message 35 of 178
dark mode would be wonderful
Message 36 of 178
This question isnt really solved and hope it gets attention from the devs. An official response would be nice. So many tools like Blender, Modo, Maya etc. come with a Dark Mode. Heck even engineering tools like nTopology have that. And that's not even mentioning Windows, Chrome extensions (and built in tags), Facebook, Whatsapp and like every other app on the planet is embracing the darkness. 😛 The Dark Side is strong with them, let's join them, they have cookies. 😄
Message 37 of 178
chrisplyler
Dark mode would be great. But don't you want them to get basic functionality right first? Like the Joint system for example? Or do you think making it pretty is a higher priority?
Message 38 of 178
in reply to: chrisplyler
@chrisplyler  Hi and thanks for your condescending response. If you think that we are asking for Dark Mode to make it "pretty" or that other tools, apps and even entire operating systems do this to make things "pretty" then I don't think you spend too much time in front of a computer or using this software. The reason is simple and meaningful - it's much easier on the eyes when you have to stare at a screen for 10 hours a day to make a living. And I do care about my eyes.
I'm a new user who hasn't used each and every feature and doesn't know the ins and outs and bugs and problems that each and every tool poses so your arbitrary statement has meaning only to you, someone who is obviously a long time user and is frustrated with the way things in this tool are. But this is not the thread to harp on about problems with "Joints" or any other feature, this is a thread about Dark Mode and you are free to make another thread about all your problems.
Message 39 of 178
not gonna use it long enough to figure if the joint system works or not as it is. if you think a dark mode is pretty then awesome enjoy that. dark mode is functional.
Message 40 of 178
Just found something of a workaround and thought I'd share it here for everyone's benefit. It does the job partly. Follow the steps in the linked article and use the Windows Magnifier to invert all screen colors: www.businessinsider.com/how-to-invert-colors-on-windows
I played around with the envrionment settings and I got the following options:
1. Completely black background with high contrast white model:
Set Environment to "Infinity Pool" and turn off the Ground Plane. See image:
Env: Infinity Pool, Ground Plane OFFEnv: Infinity Pool, Ground Plane OFF
2. Shaded background for better depth perception:
Set Environment to "Infinity Pool" and turn on the Ground Plane. See image:
Env: Infinity Pool, Ground Plane ONEnv: Infinity Pool, Ground Plane ON
For some reason the "Photo Booth" environment makes the model and grid darker and doesn't contrast as well. The model shown above uses the default Steel appearance. Hope this helps till we get an official Dark Mode! 😄
Technology Administrators
