Curved rack
pjreijiri
Curved rack
pjreijiri
Hello everyone,
I need some advice. I am trying to design a rack for guiding a machine that travels parallel to the ground. The track have linear sections and curved sections. I started my design with a rack and pinion. Is there any rack that is similar to the one in picture?
Or should I have the teeth on rack perpendicular to the floor?
Thank you
Replies (11)
etfrench
No, it isn't possible to have a set of gears like that.  As you suspected, the teeth have to be on the vertical faces.
ETFrench
pjreijiri
Would the pitch be different or it stays the same?
etfrench
The pitch (or module) of the curved and straight sections must be identical.  If you put the teeth on the outside of the curved sections, you can use the built-in spur gear script to create those teeth. See this video for more details: https://www.youtube.com/watch?v=khG4Zk5XZrw
ETFrench
pjreijiri
One me question. The chair lifts, the ones that are used for elderly people and people who cant go up the stairs. How do they operate? What is their concept? Is it rack and pinion or wheels? Since it has movement in the horizontal and vertical planes
etfrench
They can be either rack and pinion or cable driven.
ETFrench
pjreijiri
If it is rack and pinion how do they get up the stairs (vertical inclination) and have horizontal movement as well with a rack since it can't have curves in both direction?
etfrench
It depends on your point of view.  If you used the rail you show in the first post for a stair lift, it would need to be rotated 90 degrees.
ETFrench
pjreijiri
This is how the rack would look like. Any thoughts? is it feasible?
pjreijiri
If you check this video, you can see the rack curved. I want to see how to design a rack like that.
You can see it at 4:15 and later on in the video as well
https://www.youtube.com/watch?v=B5qik-AAO1w
I am not making any advertisements in any way.
TheCADWhisperer
On mating gears you want the pitch to match.
Since this rack is curved a liberal amount of clearance (backlash, slop, whatever technical term) must be allowed because you will not achieve perfect pitch along entire length.
Because the application is low speed, the extra clearance should not be an issue as long as the teeth do not skip because of the clearance.
I would run the mechanism in analysis software to verify.
pjreijiri
would proper joints and contact sets in Fusion 360 do the trick in trying to do the simulation?
also is it good practice to have the straight sections with backlash equal to an amount A and on the curved sections have a backlash bigger than A and then it goes back to A?
EDIT: another approach that I am thinking of is instead of changing the rack pitch I just increase the distance between the rack and gear, for the curved sections and then decrease it to the previous distance.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
