creating a concave radius
adventuremetal
adventuremetal
I can't figure out how to turn the slot sketch into a concave radius on the attached file. This part is going to be machined and the slot milled with a 1.25 diameter end mill.  Any help would be much appreciated.
Roger
mavigogun
A bunch of ways to do this; one- a swept profile -is attached.   I'll include a screencast in a moment.Swept Recess.JPG
mavigogun
...and a narrative.   Or another broken attempt to include a screencast.
Screencast will be displayed here after you click Post.
mavigogun
mavigogun
With the slot diameter of 0.625" and a 1.25" ball nose end mill, you could just plunge along the intended length to a finish depth of 0.08373" for a shallow concavity.
mavigogun
An even simpler way using only the existing Sketch, an Extrude, Fillet, and Combine:
adventuremetal
Thanks for the help. Use of construction plans is something I still need a lot of practice with.
Roger
