Up until yesterday the form creation tools were seemingly working fine.
Click the Create Form button, Fusion would go in to Form creation mode (in the Sculpt environment), select the form I wanted to created. It would then create a form as it did in the past, meaning it would show the purple form, with all the t-splines whose parameters I could set.
Now, what is happening is it is creating what appears to be a solid body. I say appears to be because when I hover the mouse over the form it clearly shows the subdivisions are present, all lines, points, come out, but, only when they are hovered over.
I have gone through the preferences many many times and cannot find anything which implies something is turned off.
Like I said, when i first starting using Fusion, it created the forms just as expected, it just seems to have stopped.
