Constraint bug?
- Mute
- Permalink
- Report
In this sketch a rectangle was created, then a line offset down from the top edge. A line was added 2.5" above the origin:
Adding a dimension between the endpoints of the offset line and the added line creates a normal dimension, but both lines are already constrained horizontally as well as vertically dimensioned. Expected result is a driven dimension.
Note: If the dimension as created between the lines, not the endpoints, then a driven dimension will be created.
ETFrench
