conical inside to a cylinder
Hi there,
I need help with creating a cylinder with a cone inside.
Referrring to the attached image the following need to be connected.
Rail 1  + Rail 3
Rail 2 + Rail 4
the bits between 1 and 2 + 3 and 4 should ideally be solid.
Very new to this so any help would be appreciated.
Many Thanks
Nick
As you have already created the profile sketches, you can use the loft option to do so. select create, loft option. it will prompt for 2 profiles select the profiles needed. body will be created and hit ok you are done.
TheCADWhisperer
Inside/Outside Profile Loft must be done in two steps.
1 to 3 Join.
2 to 4 Cut.
File>Export and then Attach your *.f3d file here if you can't figure it out.
chrisplyler
Why don't you just use a Revolve instead of a Loft?
And if you want to make sure the new bit you create becomes one solid with the existing bit, then make sure you are working in the same Component, and make sure the Join option is selected within the Revolve palette.
Thanks for all your help guys!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
