Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Conical Bend in Sheet Metal
20 REPLIES 20
Message 1 of 21
JDMather
3721 Views, 20 Replies
How do I create and Flatten a conical bend in Fusion sheet metal?
20 REPLIES 20
Message 2 of 21
TrippyLighting
in reply to: JDMather
What's wrong with your approach ?
It seem rather brilliant!
Message 3 of 21
daniel_lyall
@JDMather There's nothing wrong with that it works very well.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 4 of 21
etfrench
in reply to: daniel_lyall
How would you manufacture the part?  I can see using a hammer and a wooden form with the tapered radius of the bend, but how would you do it with a brake?
ETFrench
Message 5 of 21
daniel_lyall
in reply to: etfrench
You can do it with a constant radius instead, you would stamp it or do it by hand
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 21
in reply to: TrippyLighting
Im just trying to get the same/similar flat pattern to occur however doing it without the fillets. I would prefer to set the radius using the "radius bar thickness" in the sheet metal rules however I don't seem to able to get it to unfold without the fillets. Any thoughts on why this will not work?
Message 7 of 21
lichtzeichenanlage
@loganrmay: This screencast might help (sry for the title)
Message 8 of 21
in reply to: lichtzeichenanlage
Hey mate thanks for that, I can now understand the process for creating these shapes with different methods. I also noticed as well if you hit "join" when thickening saves a "combine" step. Is it possible to get a flat pattern without the fillet? If not can you explain why, sorry probably a pointless question as long as it works but i got to know!
Can anybody tell me is there a way to create similar flat patterns from developable curved sheets say those that make up the hull of a boat?
Message 9 of 21
TheCADWhisperer
@Anonymous
Can you start a new thread with this exclusive topic and post an example *.f3d file?
Message 10 of 21
I'm trying to produce something similar to this, but one end is circular. As there is no flat face I can't draw a sketch on a face to create the flange from. So I've sketched a line between the two end sketches and created a flange from that. Thickened the surface profile and joined it to the flange. Selecting either the inside or outside edge of the flange doesn't produce a flat pattern.
So what am I doing wrong?
Attached copy of file.
Message 11 of 21
AFAIK Fusion can't solve round to straight transition bends.
Message 12 of 21
That's a bummer. I wanted to produce drawings to take to a sheetmetal fabricator to make a adaptor to change from a circular duct to a rectangular inlet of a dust extractor cyclone.
Message 13 of 21
JDMather
in reply to: arie.dv
@arie.dv wrote:
I'm trying to produce something similar to this....
@arie.dv
Something like this?
Rectangle to Round.pngThis one with tighter radius in the corners.
Rectangle to Round DevelopmentRectangle to Round Development
Message 14 of 21
Hey - that's smart!
Message 15 of 21
arie.dv
@JDMather wrote:
@arie.dv
Yes. How did you do that?
All I need to do extra is add flanges for attachment to the rectangle end, also extend the circular end for the pipe to fit into.
Thanks, Arie.
Message 16 of 21
arie.dv
@JDMather wrote:
@arie.dv
Looking at your timeline I can see that the first two sketches are for the round & rectangular parts and the third sketch is for the surface trim tool to create the gap required to insert the flange. The last sketch would be for positioning the flange. What I can't figure out is what plane to draw the third sketch on and what to draw.
I've drawn my circle & rectangle on the XZ plane and the trim cut line on the YZ plane but that doesn't work because the trim tool cuts perpendicular to the sketch plane.
Some guidance on how to draw the third sketch would help me to work this out.
Thanks, Arie.
Message 17 of 21
arie.dv
OK. I think I figured out how to trim the gap in the loft and added the flange & thickened the loft but I still can't flatten the resultant model.
Have attached my version of what @JDMather did.
Regards, Arie.
Message 18 of 21
JDMather
At least 2 violations of the 4 Rules of Sheet Metal.
Bends can only be cylindrical or conical.
Flat faces must be planar.
Your part doesn't visually look like my part.
Can you identify the conical bends and the planar faces in my part image?
https://autodeskuniversity.smarteventscloud.com/connect/sessionDetail.ww?SESSION_ID=225530
Message 19 of 21
arie.dv
My normal use of Fusion is to design components and mill them out on an CNC router.
So this is my first use of the sheetmetal functionality of Fusion.
I had a quick look at https://f360ap.autodesk.com/lessons?utf8=%E2%9C%93&%2Flessons%5Bsearch%5D=sheet+metal  before attempting to create my sheet metal adaptor.
So I don't know what rules I have violated.
I can see that you have lines creating triangular portions, which I assume are the planar faces and the conical bends are the areas in between. What I don't understand is how you create them.
Regards, Arie.
PS. Here is the final product that I wish to produce.
Message 20 of 21
arie.dv
Regards, Arie.
I finally figured it out. I need to create a sketch with rails between the circle and the rectangle. Which is then used by the loft to create the planar faces.
Regards, Arie.
