conic constructions, exact equations, finding tangents
How to enter a exact dimensioned curve, and/or find the tangent at a specified angle to a general sketch curve
I am trying to make Oblate Spheroid geometry based loudspeaker horn/waveguide
the geometry is a surface of revolution of a 2D hyperbola
characterized by hyperbola asymptotic angle and the size constraint of matching a selection of specific compression driver exit angle and diameter numbers at the throat
I can guess at a couple of approaches that have a heavy math preprocessing burden, would require typing lots of high precision digits
the 3 point and Rho conic entry method needs considerable math to hit the curve starting from the parameters I have – and I can't find where you document the equations you use that would let me make the calculation
I believe a 2D spline could also be calculated to give an exact fit to a hyperbola – again clear documentation – cold hard equations documenting what your splines are made of, how to enter the parameters – would need to control slope and curvature awkwardly at the throat endpoint with tedious calculation in other math tools
obviously I'd much prefer a native geometry driven approach
I can literally make a cone by revolving a triangle with the asymptotic angle
slice the body in a plane offset from the cone axis, project the face to a sketch plane
and then I'm stuck – can't apply a tangent constraint to snap a line with the correct angle slope from the axis to the curve
I can't seem get a line to snap tangent to a 3point, Rho conic sketch either – constraint syntax, grammar needs clearer explanation – words please, actual written documentation?
Use of tangent handles to modify curves makes disambiguation difficult
So far I can only make the specified angled line snap tangent to a circle or ellipse (although 1st try warped the ellipse, “fix/unfix” made it do what I wanted)
even then the intersection point doesn't appear, I have to trim away the construction line to get the endpoint of the curve
