Cannot Select Projected Points for Ordinate Dimension
neljoshua
Advisor Advisor
neljoshua
I am attempting to use the ordinate dimension tool to dimension a circular feature.  I want the origin to be at the bottom left corner of the drawing.  To do this I need to project points--the edges of the part.  Fusion can 'see' the points and project them, but it will not allow me to select their intersection.  Saving the drawing and re-starting Fusion has no effect on this problem.
I have seen this issue before, and apparently so have others.  It appears that it may be a Mac-only bug.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
cmiller66
Hi Josh,
Unfortunately this is not currently supported.  We can create an associative dimension for the case when you have two edges which can be extended, say two edges that meet at a fillet.  Then we extend out those edges and acquire the theoretical intersection point.
For this case, while we can track to that point, we don't actually acquire it as an associative intersection - you can't place the dimension and the little x doesn't turn green.  I will check with the developers on what is required to support this, but right now it's a limitation.  You'll need to use other dimension types unless you want to set the ordinate origin on the actual part, which in this case isn't ideal.
Chris
neljoshua
@cmiller66,
Thank you for the feedback.  I appreciate the Fusion team's timely communication.
Please let me know the status of development on this; if there is not a plan to add this feature in the very near future, I will make an IdeaStation post, as I think this is one of the basic requirements for an ordinate dimensioning tool.
__
cmiller66
Hi Josh,
Please go ahead and create the IdeaStation post.  While we are aware of the request, getting more user votes for an issue does help us prioritize them.
Chris
neljoshua
@cmiller66,
Thanks again for the feedback.
To anyone who wishes to see and/or upvote the idea, here is the IdeaStation post.
__
