Bridge from square to circle
Hi all,
I am quite the beginner at Fusion 360 and I am looking to bridge a gap between a cilinder (so a circle edge) and a square. Below two screenshots to indicate the problem. My steps in sculpt mode:
- Convert the side edge of the cilinder. This results in a square around the edge. See the first screenshot.
- Convert the edge of the square (not shown)
- Bridge the cilinder edge (which is now a square) and the originally already square edge to form a cilinder/cone shaped bridge. Result shown in second screenshot
Screen Shot 2016-07-11 at 21.40.47.pngScreen Shot 2016-07-11 at 21.40.46.png
My questions:
- Why does F360 form a square around the circle when converting and is there a way to avoid this?
- The bridge is per definition a cilinder shape, but I (originally) have a square as one edge. Is there a way I can go from a cilinder to a square using the whole edges of both side? It may look a bit awkward but I don't see why this cannot work.
- The bridge never fully aligns with the edge of the cilinder (see second screenshot). I have used the match function on a different occasion to resolve this, but this does not lead to a smooth result. Is there another way to avoid this.
Would really appreciate your help. I am probably going to regret saying this, but please do not hesitate to give me direct feedback if you think it may help.
Thanks!
Richard
jeff_strater
Hi @Anonymous,
This is exactly what the Loft command is good for.  See the screencast below:
Hope this is clear.
Jeff
Jeff Strater
Engineering Director
jeff_strater
Also, I did not at first notice that you were using Sculpt to try this.  Is there a reason you want to use Sculpt?  I would tend to stick to solids for this, in which case Loft is the best tool for this problem.
Jeff
Jeff Strater
Thanks! No particular reason to use sculpt mode, loft function works perfectly indeed. I got to the sculpt > bridge function via some youtube video. Would you be able to guide me to a resource that would be discussing all the functions of Fusion360? Thanks again, Richard
jeff_strater
Hi @Anonymous,
" discussing all the functions of Fusion360" is a bit of a tall order, I'm afraid.  However, I would recommend starting with the Fusion "Getting started" training, here:  getting started with Fusion.
This site has a good collection of tutorials that will get you started.  A more general site is here, which contains more complete documentation.
Jeff
Jeff Strater
TrippyLighting
You are on that resource!
We discuss ALL Fusion 360 topics here on the Forum 😉
This might not be a satisfactory answer for you at the moment, but if you come here often and go through posts you'll find that this is a treasure trove of creative solutions that are really hard to cover in another form.
