Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
BOM Balloon with a sub-assembly
6 REPLIES 6
1333 Views, 6 Replies
Hi
How do I get the BOM  balloon to reference the Sub-assy level instead of at the component (part) level?
The BOM balloon for the 'metalwork' sub-assy should be the same as the item number in the BOM which is (3).
However the BOM balloon is showing (7) which is the item number of a component (part) in the sub-assy.
6 REPLIES 6
Keshava_Murthy
Thanks for posting and sorry for your situation.
I tried replicate your model / drawing pattern but i couldn't reproduce the issue which you are mentioning.
Is it possible to attach your model here or share directly to me at keshava.gopalakrishnaiah@autodesk.com
Please click ACCEPT SOLUTION if my post helps in solving your issue or answering your question.
Keshava Murthy
AutoCAD Mechanical Team
in reply to: Keshava_Murthy
Hi Keshava,
Thanks for the reply. I have just shared the project folder with you the
file name is (AFC-01-000) and the drawing is (AFC-01-000 Drawing).
Beyondforce
Hi @Anonymous,
Please check out this post. It will helpfully answer your question:
https://forums.autodesk.com/t5/fusion-360-support/drawing-bom-counter-bug/td-p/7278922
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
in reply to: Beyondforce
Hi Ben,
my issue looks slightly different to yours but it does appear to be a few unresolved bugs in Fusion BOM.
Hi Keshava,
Have you had a chance to look at this yet?
nick.ni
Hi mpjunkmail,
Keshava is on vocation today and tomorrow. Let me try to answer your question.
I can reproduce your issue with following steps:
1. create a storyboard view in the drawing.
2. add balloons and parts list in the drawing.
3. suppress all other components expect the subassembly. notice that parts list and the balloon number on the subassembly are updated. (in your case, the subassembly's balloon number becomes 7)
4. unsuppress all components. Notice that the parts list is updated correctly. But the subassembly's balloon number is not updated, which is a issue.
The issue is known to us. We will fix it together when we start a project to support parts list hierachy in Fusion drawing.
The current workaround is to renumber the balloon number using "Renumber" command.
(Please let me know if the issue in your drawing has different workflow as what I described. )
Regards
Nick Ni
Product Owner
Quality Assurance
Autodesk, Inc.
