- Mute
- Permalink
- Report
Does anyone out there know how you would use F360 to create v-carve inlays? For those who don't know, v-carve inlays take a positive relief and a negative relief cut with a v bit in contrasting materials. The two are mated and one is cut or sanded away to reveal an inlay with perfectly sharp inside and outside corners.
This is a really great technique for decorative work because you don't need absolutely tiny bits to avoid rounded corners.
The Vectric software has built in scripts, but I assume it isn't too difficult to recreate the steps manually. I'm more the artist than the computer guy so I'm having trouble thinking it through. Logically it doesn't seem too complicated. There are only a few things to keep in mind. For eg. the positive shouldn't bottom out when mated so that you can be assured of a good fit. Is there an evangelist out there who knows how this is done? Here is there Youtube video on how Vectric has done it:
