Problem with loft after last Fusion update (plugin doesn't work)
marcinszydlowski.1984
Hello everyone,
I use loft in my plugins. After last Fusion update this funcitionality doesn't work as before, I mean clients get errors, no matter loft is through profiles with rails or not. Making loft by UI works (but for rails I need to turn off "Chain selection" checkbox).
I prepared sample script to show one of the case. There's no error messages but lofts are not as expected:
It seems that loft starts from middle profileIt seems that loft starts from middle profile
Script:
import adsk.core, adsk.fusion
def run(context):
    app = adsk.core.Application.get()
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    rootComp = design.rootComponent
    # Example 1 - same size of profiles but different Z
    sketch1 = rootComp.sketches.add(rootComp.xYConstructionPlane)
    # First profile
    p11 = adsk.core.Point3D.create(0, 2, 0)
    p12 = adsk.core.Point3D.create(2, 0, 0)
    p13 = adsk.core.Point3D.create(0, -1.3, 0)
    p14 = adsk.core.Point3D.create(-1.8, 0, 0)
    p15 = adsk.core.Point3D.create(-1.2, 1, 0)
    sketch1.sketchCurves.sketchLines.addByTwoPoints(p11, p12)
    sketch1.sketchCurves.sketchLines.addByTwoPoints(p12, p13)
    sketch1.sketchCurves.sketchLines.addByTwoPoints(p13, p14)
    points = adsk.core.ObjectCollection.create()
    points.add(p14)
    points.add(p15)
    points.add(p11)
    sketch1.sketchCurves.sketchFittedSplines.add(points)
    # Second profile
    p21 = adsk.core.Point3D.create(0, 2, 4)
    p22 = adsk.core.Point3D.create(2, 0, 4)
    p23 = adsk.core.Point3D.create(0, -1.3, 4)
    p24 = adsk.core.Point3D.create(-1.8, 0, 4)
    p25 = adsk.core.Point3D.create(-1.2, 1, 4)
    sketch1.sketchCurves.sketchLines.addByTwoPoints(p21, p22)
    sketch1.sketchCurves.sketchLines.addByTwoPoints(p22, p23)
    sketch1.sketchCurves.sketchLines.addByTwoPoints(p23, p24)
    points.add(p24)
    points.add(p25)
    points.add(p21)
    # Third profile
    p31 = adsk.core.Point3D.create(0, 2, 10)
    p32 = adsk.core.Point3D.create(2, 0, 10)
    p33 = adsk.core.Point3D.create(0, -1.3, 10)
    p34 = adsk.core.Point3D.create(-1.8, 0, 10)
    p35 = adsk.core.Point3D.create(-1.2, 1, 10)
    sketch1.sketchCurves.sketchLines.addByTwoPoints(p31, p32)
    sketch1.sketchCurves.sketchLines.addByTwoPoints(p32, p33)
    sketch1.sketchCurves.sketchLines.addByTwoPoints(p33, p34)
    points.add(p34)
    points.add(p35)
    points.add(p31)
    # Create loft
    loftFeatures = rootComp.features.loftFeatures
    loftInput = loftFeatures.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    for ip in range(sketch1.profiles.count):
        loftInput.loftSections.add(sketch1.profiles.item(ip))
    loftInput.isSolid = True
    loft = loftFeatures.add(loftInput)
    # Example 2 - different sizes of profiles
    sketch2 = rootComp.sketches.add(rootComp.xYConstructionPlane)
    xShift = 10
    # First profile
    p11 = adsk.core.Point3D.create(0 + xShift, 2, 0)
    p12 = adsk.core.Point3D.create(2 + xShift, 0, 0)
    p13 = adsk.core.Point3D.create(0 + xShift, -1.3, 0)
    p14 = adsk.core.Point3D.create(-1.8 + xShift, 0, 0)
    p15 = adsk.core.Point3D.create(-1.2 + xShift, 1, 0)
    sketch2.sketchCurves.sketchLines.addByTwoPoints(p11, p12)
    sketch2.sketchCurves.sketchLines.addByTwoPoints(p12, p13)
    sketch2.sketchCurves.sketchLines.addByTwoPoints(p13, p14)
    points.add(p14)
    points.add(p15)
    points.add(p11)
    sketch2.sketchCurves.sketchFittedSplines.add(points)
    # Second profile
    p21 = adsk.core.Point3D.create(0 + xShift, 4, 4)
    p22 = adsk.core.Point3D.create(4 + xShift, 0, 4)
    p23 = adsk.core.Point3D.create(0 + xShift, -2.6, 4)
    p24 = adsk.core.Point3D.create(-3.6 + xShift, 0, 4)
    p25 = adsk.core.Point3D.create(-2.4 + xShift, 2, 4)
    sketch2.sketchCurves.sketchLines.addByTwoPoints(p21, p22)
    sketch2.sketchCurves.sketchLines.addByTwoPoints(p22, p23)
    sketch2.sketchCurves.sketchLines.addByTwoPoints(p23, p24)
    points.add(p24)
    points.add(p25)
    points.add(p21)
    # Third profile
    p31 = adsk.core.Point3D.create(0 + xShift, 3, 10)
    p32 = adsk.core.Point3D.create(3 + xShift, 0, 10)
    p33 = adsk.core.Point3D.create(0 + xShift, -1.95, 10)
    p34 = adsk.core.Point3D.create(-2.7 + xShift, 0, 10)
    p35 = adsk.core.Point3D.create(-1.8 + xShift, 1.5, 10)
    sketch2.sketchCurves.sketchLines.addByTwoPoints(p31, p32)
    sketch2.sketchCurves.sketchLines.addByTwoPoints(p32, p33)
    sketch2.sketchCurves.sketchLines.addByTwoPoints(p33, p34)
    points.add(p34)
    points.add(p35)
    points.add(p31)
    # Create loft
    for ip in range(sketch2.profiles.count):
        loftInput.loftSections.add(sketch2.profiles.item(ip))
When I do this by UI it works:
Order is okOrder is ok
What should I do to make this work by API?
There's also another problem in case of using rails because I cannot find an equivalent of "Chain Selection" in API. Is it accessible or is it performed on much higher level?
Solved. If you have similar problems, try to make each profile in dedicated sketch (no matter profile is CW or CCW). If you need rails they also should be in a separate sketch.
