TSpline to BRep Convert
Hi !
Is there a way to convert a TSpline object to BRep using API (python) ?
BrianEkins
There's no need to have a method to convert a T-Spline to a B-Rep model because Fusion does this automatically when you leave the "Form" mode.  You can see this if you create a new part, create a new T-Spline model, and then write a program to get the BRepBody objects available in the root component.  You should see one, which is a result of the T-Spline being converted to a B-Rep.
Brian Ekins
