'Edit Face' via API
'Edit Face' via API
'Edit Face' via API
I'd like to be able to edit the shape of a BRepFace via the API (in much the same way the 'Edit Face' function works)- is this possible?
Anyone?
kandennti
Hi NathanAdvMfg.
In order to do 'Edit Face' with API, I think that it will handle Form (TSplineBody),
There is probably no way to edit TSplineBody with the API.
If there is workability, I think that there is no choice but to export TSplineBody and edit the file (TSM file).
Import / export is provided, so I have created this add-in
https://github.com/kantoku-code/Fusion360-TSplineBodyDoorway
There is not much material in the format of TSplineBody (TSM file), but this seems to be applicable.
http://iranarze.ir/wp-content/uploads/2016/11/E524.pdf
Although it is a personal opinion, I think it is not impossible, but it is quite difficult.
Thanks @kandennti  - interestingly, this was very similar to the suggestion of another developer I spoke with.
