Can't get bRepBodies from imported STEP file
11713013
11713013
Hi, there
I am writing a script to automatically generate a twist beam.
Here is my plan:
First, import the start joint and end joint to a Fusion 360 design.
Second, put them at a specific position with specific posture.
Then, get the faces for loft features.
Finally, generate the loft feature to get the twist beam.
By now, I have finished my first two steps with Fusion 360 API script.
I think I should get bRepBody first and then get the face from the bRepBody for the profile for loft.
But I am getting trouble for get bRepBodies from a component:
        allBodies = joint_down_comp.bRepBodies
        if allBodies.count < 1:
            ui.messageBox("Body count is not exist")
            return
        else:
            ui.messageBox("Find " + str(allBodies.count) + " bRepBodies")
            return
 It show that the number of bRepBodies is zero.
I get zero bRepBody from rootComp either.
So, how can I get the bRepBody from the imported STEP file for getting the faces to loft?
Here is my full code:
import os, sys, math
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # ui.messageBox('Hello script')
        importManager = app.importManager # get importManager
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        rootComp = design.rootComponent # get the root component
        objCollection = adsk.core.ObjectCollection.create()
        # Create a new occurrence to create an associated component to hold the first joint step
        trans1 = adsk.core.Matrix3D.create()
        occ1 = rootComp.occurrences.addNewComponent(trans1) # the default trans matrix do not move the component from rootComp
        joint_up_comp = occ1.component
        joint_up_comp.name = "Up-Joint"
        # Import the up joint step to the origin point
        stepFileName1 = os.path.join(os.path.abspath(os.path.dirname(__file__)), "./STEP/joint_part_up.STEP")
        stepImportOptions1 = importManager.createSTEPImportOptions(stepFileName1)
        objUp = importManager.importToTarget2(stepImportOptions1, joint_up_comp)
        objCollection.add(objUp)
        # Create another occurrence to create an associated component to hold the below joint
        trans2 = adsk.core.Matrix3D.create()
        length = 10.0 # it is the length for loft(10cm)
        vec2 = adsk.core.Vector3D.create(0.0, 0.0, length+4) # the extral part of two joint is 40mm
        trans2.translation = vec2
        occ2 = rootComp.occurrences.addNewComponent(trans2)
        joint_down_comp = occ2.component
        joint_down_comp.name = "Down-Joint"
        # Import the down joint step to the setting point
        stepFileName2 = os.path.join(os.path.abspath(os.path.dirname(__file__)), "./STEP/joint_part_down.STEP")
        stepImportOptions2 = importManager.createSTEPImportOptions(stepFileName2)
        importManager.importToTarget(stepImportOptions2, joint_down_comp)
        # Using transform to move the occurrence
        origin = adsk.core.Point3D.create() # to store the origine point of the occurrence's coordinate system
        xAxis = adsk.core.Vector3D.create() # to store the xAxis of the occurrence's coordinate system
        yAxis = adsk.core.Vector3D.create() # to store the yAxis of the occurrence's coordiante system
        zAxis = adsk.core.Vector3D.create() # to store the zAxis of the occurrence's coordiante system
        (origin, xAxis, yAxis, zAxis) = occ2.transform.getAsCoordinateSystem() # get the occurrence's coordinate system
        rotY = adsk.core.Matrix3D.create()
        rotY.setToRotation(math.pi, yAxis, origin)
        trans3 = occ2.transform
        trans3.transformBy(rotY)
        occ2.transform = trans3
        # twist the down joint
        theta = math.pi/6 # twist angle
        (origin, xAxis, yAxis, zAxis) = occ2.transform.getAsCoordinateSystem() # re-get the occurrence's coordinate system
        rotZ = adsk.core.Matrix3D.create()
        rotZ.setToRotation(theta, zAxis, origin)
        trans4 = occ2.transform
        trans4.transformBy(rotZ)
        occ2.transform = trans4
        # ui.messageBox(str(xAxis.length))
        # add assembly clearance
        trans5 = occ2.transform
        # transY = yAxis.scaleBy(0.1) # translation alonge the y axis by 0.1 cm
        transY = adsk.core.Matrix3D.create()
        vecY = adsk.core.Vector3D.create(yAxis.x / 10, yAxis.y / 10, yAxis.z / 10)
        transY.translation = vecY
        trans5.transformBy(transY)
        occ2.transform = trans5
        # get the faces for loft feature
            return
        else:
            return
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Also, I put my script as a zip file in the attachment.
tykapl.breuil
Hey there, just tested it out, when importing you are already creating a component which means everything is nested one more time hence why you can't find the bodies ;).
I would advise to rename the component created by the import rather than creating a new one and your script should work wonders.
Thank you so much for your reply.
You are right! The problem is caused by nesting the components. I just put the STEP file in the rootComp and solved this problem.
But here is another problem for getting the profiles of loft features.
I rewrite my code into this:
def run(context):
    ui = None
    try:
        importManager.importToTarget(stepImportOptions1, rootComp)
        importManager.importToTarget(stepImportOptions2, rootComp)
        occ1 = rootComp.occurrences.item(0) # refers to joint_part_up:1
        occ2 = rootComp.occurrences.item(1) # refers to joint_part_down:1
        ## Using transform to move the occurrence
        # rotate joint_part_down for 180 degrees along its y axis
        # translate along the world coordinate z axis
        length = 10.0 # the distance between two faces for loft, unit: cm
        transZ = adsk.core.Matrix3D.create()
        transZ.translation = adsk.core.Vector3D.create(0.0, 0.0, length+4) # the extral part of two joint is 40 mm
        trans = occ2.transform
        trans.transformBy(transZ)
        trans.transformBy(rotZ)
        trans.transformBy(transY)
        # get bRepFaces for loft feature
        point1 = adsk.core.Point3D.create(0.0, 0.0, 2.0)
        face1 = rootComp.findBRepUsingPoint(point1, adsk.fusion.BRepEntityTypes.BRepFaceEntityType)
        # loops1 = face1.item(0).loops # bRepLoops
        # loop1 = loops1.item(0) # bRepLoop
        # edges1 = loop1.edges
        edges1 = face1.item(0).edges
        # ui.messageBox(str(edges1.count))
        profile1 = rootComp.createBRepEdgeProfile(edges1)
        # path1 = adsk.fusion.Path.create(edges1, adsk.fusion.ChainedCurveOptions.tangentChainedCurves)
        point2 = adsk.core.Point3D.create(0.0, 0.0, length+2.0)
        face2 = rootComp.findBRepUsingPoint(point2, adsk.fusion.BRepEntityTypes.BRepFaceEntityType)
        # loops2 = face2.item(0).loops
        # loop2 = loops2.item(0)
        # edges2 = loop2.edges
        edges2 = face2.item(0).edges
        profile2 = rootComp.createBRepEdgeProfile(edges2, False)
        # path2 = adsk.fusion.Path.create(edges2, adsk.fusion.ChainedCurveOptions.tangentChainedCurves)
        # create loft feature input
        loftFeats = rootComp.features.loftFeatures
        loftInput = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        loftSectionsObj = loftInput.loftSections
        loftSectionsObj.add(profile1)
        loftSectionsObj.add(profile2)
        loftInput.isSolid = False
        loftInput.isClosed = False
        loftInput.isTangentEdgesMerged = True
        loftFeats.add(loftInput) # create loft feature
    except:
        if ui:
However, a new problem comes out:
Failed:
Traceback (most recent call last):
  File "C:/Users/61648/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/LegGenerating/LegGenerating.py", line 81, in run
  File "C:/Users/61648/AppData/Local/Autodesk/webdeploy/production/50d1a2b00ac928c7781cbca6551e586a5384d498/Api/Python/packages\adsk\fusion.py", line 42403, in createBRepEdgeProfile
    return _fusion.Component_createBRepEdgeProfile(self, edges, chainEdges)
RuntimeError: 3 : invalid input edges
But I think I got correct bRepEdges because I output the number of edges and it shows the number of edges1 is 8(
ui.messageBox(str(edges1.count))).
Fusion360 API seems not easy for me when getting problems and it costs me a lot time.
Hoping for your reply!
