Hi Tomislav,
This is still an issue, and I apologize. We need to get this fixed.
In the meantime, there is a workaround you can try:
- Put everything you're working on inside a single container Group at the Main Sketch level (not inside another Group).
- Copy the Group and Paste-in-Place (Ctrl + Shift + V) to create an exact duplicate in the same position in space.
- Create a new Layer and name it something clearly indicating it's the scaled version. When you Paste-in-Place, the copied Group will be selected automatically, so you can easily put that selection on the new Layer.
- Scale the new Group 328.08% to account for the scale factor of feet-to-meters.
- You can temporarily turn off the new Layer that contains the scaled Group, and continue modifying geometry in the original Group, and every change you make there will propagate to the scaled Group.
- When you're ready to export, you can turn on the "scaled" Layer, select that Group, and File > Export Selected, to your desired file format. This should result in geometry that's the correct scale. Then you can simply turn off that scaled Layer and continue working.
This isn't ideal, but might work in a pinch until we release FormIt with the ability to specify the export scale. After the first-time setup, this should require minimal work for a file that you repeatedly export to another format - just toggle the appropriate Layer when Exporting Selected, then turn it off, and continue working as you normally would in the non-scaled Group.
Josh Goldstein
Senior Product Manager
