Sync Issues - 360 Drive to Formit iOS
bradburch
bradburch
I've converted a SketchUP file to .RVT via the 2016 convertion add-in.  These files are present and in the same directory as my other Formit models, but not visible in the iOS app.
Formit models that originated on my iPad are correctly syncing with 360 online, so I know it's working in at least one direction.
Any ideas?
iOS 9.1
Formit 360 12.2
tvollaro
Files that are converted with the Converter cannot be loaded as a sketch. They are intended to be be loaded by using the Content Library. see this page for more info: http://help.autodesk.com/view/FORMIT/ENU/?guid=GUID-396A23FE-ED47-4847-94A1-63826D9A1E1B
Tom Vollaro
Experience Design Architect - Autodesk
bradburch
Thanks, I was able to locate the models in 'contents'.
By the way, the link does't work.
tvollaro
Try this link instead: http://help.autodesk.com/cloudhelp/ENU/FormIt-UsersGuide/files/GUID-396A23FE-ED47-4847-94A1-63826D9A...
Tom Vollaro
