Some ACIS objects could not be imported.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been vetting a workflow process regarding sketchup -> Formit -> Revit. I've tried alot of files Some internal, some from 3D Warehouse and other sites, with every file
I use the the Convert from SKP to Formit Button - then use the Formit to RVT button. I never get a clean import I always end up with the following error:
Some ACIS objects could not be imported. To import them, use AutoCAD to convert them into polymesh objects and reimport.
I get a host of follow up errors about Rotating object into place,Mass will not be able to create floors and then i get stuck cycling between those 3 errors until I have to kill revit. I loaded up the journal file, but nothing jumped out at me other than it is cycling through each and every group Formit creates prior to import.
Going from Sketchup to AutoCAD was kind of the old way to get anything into Revit. I was hoping to avoid AutoCAD all togther. Since i get the error with Large files, small files, personally created or downloaded files, I feel like I am using the tool incorrectly, or i'm not following the correct workflow. Either way - it would awesome if anyone else has run into this.
Thank you!
M
