Sketchup to Formit Conversion Fails
jdeans
jdeans
Every time I try run the conversion tool on a sketchup file it fails with the message "Problem occurred during conversion.  Please check the log file for more details."  I have tried this with both the Revit 2015 and 2016 plugins as well as on multiple sketchup files either that I created myself or that were downloaded from the 3D warehouse with the same results.  I have also tried running Revit as administrator.  I have attached a copy of the log file I'm getting.
Tobias_Hathorn
Hi there - I have had that error happen on a few SKP files, but then the next one I tried worked out fine - I haven't found a pattern yet. Would you be willing to share a few of the SKP files that fail for you? I can work with our development team to see if there's something we can resolve there.
I'll try sending you a direct message - but if that doesn't work, will you try sending me a direct message?
You can find the link to send a direct message by hovering over my name in the upper left portion of this post and click on 'Send a message'
Thanks!
Tobias
