Announcements
Sketchup components converted in Formit
I am currently using the web based version of Formit. Is there a way to convert faceme objects from Sketchup into Formit?
josh.goldstein
Hi Fernand,
Unfortunately, you can't import SketchUp geometry directly into the web version of FormIt.
However, you can do this with FormIt for Windows, or, if you have access to Revit, you can use the FormIt Add-In for Revit to select SKP files and convert them to the FormIt file format, and then import those converted files into the Web app.
Note that SketchUp face-me components will import with geometry/layers/materials/component structure intact, but they will not face the camera in FormIt. We're looking into ways to address this in a future update.
Josh Goldstein
Product Lead
Thank you for your prompt response. I look forward to the future update if possible.
