Solved by vollart. Go to Solution.
I am sorry you are having trouble. It looks like the file was corrupted. A couple of things you can try.
I can see from your screenshot that your FormIt on iOS is logged into Autodesk 360 (because the user icon is solid blue.) Also, since the cloud icons on each of your files is white (and not gray) that means they have been saved to the Autodesk 360 account that you logged into with. So, go to http://360.autodesk.com on your desktop/laptop and log in with the same user name/password. From there, you can click on Documents, then go to the FormIt folder. Inside that folder you will see each of your files with an .AXM file extension. Right click on the file and choose Download. Then, reply to mne and attach that AXM file.
When I try to post with the AXM file IT comes up with this message. I Filled Everthing Out Too.
Correct the highlighted errors and try again.
I am still waiting for the forum administrators to add AXM as a supported file format.
In the meantime, use this upload form instead:
I got the file, but it appears to be empty. The next thing to try is to log back into 360.autodesk.com, click on the skyscraper.axm file, and then click Versions. From there, you should see previous versions. You can click the little "clock" icon to roll back to an earlier version
Thank you so much for your help. Using your instructions I was able to find an older version of the project. It's quite a bit different than the version I lost, but at least it's something. Can you explain how I may have lost the file and how I can prevent it from happening again? Should I be saving more frequently or should I be backing it up somewhere?
Thanks again.
Honestly, I am not sure what happened. FormIt is normally very good at restoring the last good state of the model if the app crashes. Somehow, your file got corrupted and emptied. Saving more often cannot hurt!
