I’ve just updated the Formit app on my iPad Pro. . Unfortunately this has rendered the app unusable. My existing projects appear but as soon as I select one the app closes. I’m still running iOS 15.7 do I have to update to the latest iOS ?(don’t want to if I don’t have to)
*UPDATE* I have tried deleting the App and reinstalling but still the same problem. As soon as I select an existing project or start a new project the app crashes taking me to my iPad Home Screen.
Solved by josh.goldstein. Go to Solution.
Hi @mikehayes333,
We released a new version of FormIt for iPad to address a problem on iPadOS 17.
Unfortunately with this update, we are subject to Apple's minimum version requirement, which is now iPadOS 16. You'll need to update to iPadOS 16 or later to use FormIt.
Sorry for the inconvenience. It's not ideal, but also not in our control.
Hi @mikehayes333,
Thanks Josh for your reply, much appreciated. I thought it would probably be a case of updating the iOS, something I really should do anyway.
Seasons greetings to you : )
