How I can see toolbar again when the toolbar is disappeared?
Message 1 of 8
I am using formit 360 web.
How I can make the toolbar of formit to appear again when it is disappeared?
I have had this problem many times when I use formit 360 web.
Best,
Sungbok
Replies (7)
Message 2 of 8
Tobias_Hathorn
Ah - yes - I do remember seeing this issue occasionally - it has to do with scrolling the canvas in a web browser... if you accidentally hit the space bar then that scrolls a web page! and the toolbar is above the scroll - you can hit Page Up or Page Down to resolve it.
Hope this helps!
Tobias
Message 3 of 8
Tobias_Hathorn
I have seen this before on web - I think it is due to the space bar doing a scroll page operation in a browser (like a chrome or firefox shortcut taking precedent over FormIt shortcuts) so to resolve it you can hit Page up or Page down to bring the toolbar back!
Hope this helps!
Tobias
Message 4 of 8
Thanks.
I can see the toolbar again after I apply your advice.
Message 5 of 8
Hello Tobias,
I have tried this solution but am not seeing the tool bar.
Help!
Chris
Message 6 of 8
It is a glitch due to having more layers than the layer box holds... when I add an additional layer that bumps it down, the tool bar goes away....
Thoughts?
C
Message 7 of 8
josh.goldstein
Hi all,
We've confirmed a bug in FormIt Web where adding too many Layers and Scenes can cause the Project Bar at the top to disappear. Sorry for the inconvenience. We'll work on getting this fixed.
When this happens, you can use keyboard shortcut Ctrl + S to save the file to A360 Drive, then reload FormIt for Web, and open the file again. The Project Bar will be visible at that point, but adding more Layers or Scenes to the same file will unfortunately cause the issue to appear again.
You can also use FormIt for Windows which handles cases like this without issue, until we get this resolved in the web app.
Josh Goldstein
Senior Product Manager
Message 8 of 8
Tobias_Hathorn
Another temporary workaround is to zoom the contents of your browser down from 100%... this is a temporary solution of course, but will allow you to see more layers / scenes before the toolbar disappears.
