Grid rotate
Grid rotate
Grid rotate
Hello
I'm brand new to Formit and to this forum.  Thank you for an amazing product!
Using the latest version of Formit on an iPad with the latest version of iOS, I'm having a few problems:
1. I can't seem to rotate the grid.  I imported a satellite view of the site and am trying to rotate the Formit grid to line up with the streets on the site.  I press and hold down on the grid area (away from the satellite view) and then tap on the rotate grid icon (the axes with the circle and grid) but when I try to rotate just the grid, the satellite view rotates with it (the same as if I hadn't used the rotate grid command).  What am I doing wrong?
2. Is there any kind of written tutorial.  I'm trying to learn how to use it and have found some videos, but nothing that describes it from start to "finish".
Thanks!
Tobias_Hathorn
Welcome!
I think you're tapping the 'reset grid rotation' button instead of the 'grid rotation'. Use the button with the axes and the grid, but not the 'reset' icon 🙂
Then you'll see the XYZ widget appear in the canvas. Now grab the grip on the end of the red axis and you can line up the grid as you're describing.
One tip is to make the satellite image semi-transparent so you can see both at the same time. When you're done rotating grid, then click off into space!
Here's a youtube video about this tool... https://www.youtube.com/watch?v=eAl7l-ICNQA
As far as other tutorials... we have LOTS of good stuff on youtube!
Check out this playlist for getting started with the various tools
https://www.youtube.com/playlist?list=PLqumTDi1CVHPYm8E9gJg9WNWxeNoSDFkx
Check out these two videos for putting various tools together to create a building
https://www.youtube.com/watch?v=iRzAuuxj-sU&list=PLqumTDi1CVHM7rCHJs83Yb2FyadmuQsiH&index=8
https://www.youtube.com/watch?v=wJoFH4CXPbo&list=PLqumTDi1CVHM7rCHJs83Yb2FyadmuQsiH&index=6
Check out this video for a good start to finish workflow including importing and exporting with Revit
https://youtu.be/dvdUVs68NJ4?list=PLqumTDi1CVHM7rCHJs83Yb2FyadmuQsiH
You're so right! Wrong button. Thank you for setting me straight (pun intended).
And thank you for the links to the videos. I plan to watch them all.
This is is very helpful: great product, great forum.
