formit pro
formit pro
luke_larose
Message 1 of 31
formit pro
luke_larose
i have been using formit now for a few months and right from the beginning I've been running into this issue were almost every time i group an object half of the app screen goes black and only way to get it back i got to save and ten close and restart the app is there any solution to this issue ??
Replies (30)
Message 2 of 31
pendean
Community Legend
Community Legend
You are in the incorrect forum. I'll ask the admins to move your post
https://formit.autodesk.com/
https://forums.autodesk.com/t5/formit/ct-p/141
Message 3 of 31
luke_larose
ok thank you
Message 4 of 31
josh.goldstein
Hi @luke_larose! Thanks for writing in.
Yes, this is a very unfortunate issue with the UI engine that FormIt uses for the desktop app. ☹️ The "black triangles" issue, as it's affectionately known internally, is especially frustrating because we've not been able to isolate exactly what causes it, and there's no workaround other than saving the model and restarting FormIt.
One thing we have learned is that it may be related to one of the plugins. I see from your screenshot (thanks!) that you've got some plugins installed. They're super powerful! Unfortunately, they're using a web-based rendering engine that may have a weird timing collision with the desktop app and one of them may be causing the black triangles to happen more frequently.
Would you mind telling us what plugins you've got installed? There's one in particular - Properties Plus - which is likely a culprit since it does some calculations with every selection. I wrote the majority of our plugins, so it pains me to suggest disabling one or more of them, but it might be worth trying to see if it mitigates the problem. The issue is not with the plugin itself, but the engine that displays it along with the rest of the desktop user interface.
Let us know what plugins you're running, and if the set includes Properties Plus, maybe try uninstalling it and seeing if the issue happens less frequently?
Josh Goldstein
Senior Product Manager
Message 5 of 31
luke_larose
This is list of what I have installed. Dynamo eyedropper, filled 2d corners
flip along, luminous live sync manage attributes, manage axes, mesh+ unmesh
all, plug in playground, jffg guide lines, 3d context creator and none of
them seem to have that one your talking about in them..
Message 6 of 31
josh.goldstein
Manage Attributes updates on selection change as well. Try uninstalling that and restarting FormIt.
Josh Goldstein
Message 7 of 31
luke_larose
Ok, i will try that. I'll keep yall posted
Message 8 of 31
luke_larose
well i did try what was suggested and it did not fix the issue i have issue were almost every time i group or ungroup objects i get black tringels...
Message 9 of 31
josh.goldstein
Sorry that it's still happening.
Can you try uninstalling all plugins so we can eliminate those as a variable?
Josh Goldstein
Message 10 of 31
luke_larose
ya i tried that after the first step didnt work..
Message 11 of 31
josh.goldstein
Ok, and you restarted FormIt after uninstalling them? Restarting is important to fully clear plugin background code from the session.
If you restarted after uninstalling, then it's not the plugins. We very rarely see this issue, so it's hard to know what else could be causing this. Does the issue happen on any model? Are you using the G shortcut to group or some other way?
Can you also share your computer specs?
Josh Goldstein
Message 12 of 31
luke_larose
ya i went and restarted i've uninstalled and ya it happens no matter which
way i group or ungroup.... but at least it doesn't happen every time i
group or ungroup...
Message 13 of 31
josh.goldstein
Does it happen on every model? Even a new one?
Josh Goldstein
Message 14 of 31
josh.goldstein
A few other ideas:
  • Are you using multiple monitors? If so, try a single monitor
  • Can you try updating your graphics driver? Not sure if you're on NVIDIA or AMD but I can provide a link if you need
    • Also should make sure that if you have a discrete GPU, that FormIt is using that instead of the integrated chip
  • Can you try disabling the Groups Tree panel?
Josh Goldstein
Message 15 of 31
luke_larose
y aim running 3 monitor it was the same on 1 monitor and i'm running amd
radeon graphics.. i've spent alot on upgrading laptop to have more that
what autodesk recommended for programs...
Message 16 of 31
josh.goldstein
Can you try closing the Groups Tree and Undo Manager panels?
Josh Goldstein
Message 17 of 31
luke_larose
i dont have group trees and under manager turned on anymore i shut
everything off before the uninstall and haven't turned everything back on..
Message 18 of 31
josh.goldstein
Then it might be something with your graphics card. Have you checked that:
  • Windows is set to use the AMD graphics card for FormIt
  • AMD graphics drivers are up-to-date
Josh Goldstein
Message 19 of 31
luke_larose
yes is does even when i open on thats been sent to me from someone else
work..
Message 20 of 31
josh.goldstein
Worth checking the graphics driver configuration from my previous message.
Josh Goldstein
