Formit Login / Activation problem (Proxyserver)
sven.bosse
sven.bosse
Hello from Germany
We use the AEC Collection, the switch to the Autodesk product family 2022 has currently been completed.
Formit was installed for the first time.
However, the software does not start properly. After entering the Autodesk login data, further use is blocked.
The problems after the first login vary between two variants
- Variant a: It stays with the formit page and the login please (endless loop between login and the reference to the login)
- Variant b: Shows the reference to the activation server and also shows a "Repeat" button.
Since this is a municipal authority, different IT departments and IT service providers are affected.
All network traffic is routed through a proxy server. (obligation)
In the first step, access to the URls from the following articles was released:
https://knowledge.autodesk.com/de/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/DEU/I...
https://knowledge.autodesk.com/de/support/formit-pro/troubleshooting/caas/sfdcarticles/sfdcarticles/... your-internet-connection-and-try-again.html
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U... https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-requests-to-Autodesk-servers-blocked-by-proxy-servers.html
In the second step, the urls were released, which were determined by network scan or via the proxy server. This step was also unsuccessful.
Do you have any experience with Formit and proxy servers?
Does Formit have a log function or log file?
Versions:
Format 22.1.1. from 03/22/2022
Autodesk Licensing Service Updates 12.0.1.5
Windows 10 - 64 bit
josh.goldstein
Hi @sven.bosse,
Sorry for the inconvenience.
I see it's mentioned in those help articles, but just to check: Have you tried adding *.autodesk.com to your network whitelist?
Josh Goldstein
Senior Product Manager
sven.bosse
The whitelist was fed with the following urls.
Loadingsreen
formit-localization.s3-us-west-1.amazonaws.com
f360acom-p-ue1-li.cosv2-p-ue1-dn.autodesk.com
accounts.autodesk.com
tags.tiqcdn.com
js-agent.newrelic.com
dpm.demdex.net
damassets.autodesk.net
bam-cell.nr-data.net
autodesk.demdex.net
smetrics.autodesk.com
cm.everesttech.net
aa.agkn.com
idsync.rlcdn.com
dp2.33across.com
cm.g.doubleclick.net
pixel.quantserve.com
c.bing.com
ml314.com
sync.crwdcntrl.net
After Lizenzcheck
www.googletagmanager.com
developer.api.autodesk.com
images.profile.autodesk.com
metering.autodesk.com
ase.autodesk.com
ase.autodesk.com
ase.autodesk.com
material-server.formit.autodesk.com
raw.githubusercontent.com
formit3d.github.io
formit3d.github.io
ase.autodesk.com
fonts.autodesk.com
fonts.autodesk.com
formit3d.github.io
kit.fontawesome.com
cdn.jsdelivr.net
unpkg.com
ka-f.fontawesome.com
cdn.skypack.dev
api.github.com
This was determined by means of a network scan on a private computer (not running in the company network) using the Wireshark program. This list was then added to the whitelist (Proxyserver Company Network)
*.autodesk.com etc. Are also on the whitelist. wildcard releases were also tried
Other Autodesk products like Autocad 2020 + 2022, Civil 2020 + 2022, 3DS, Revit 2020 + 2022, Recap, Infraworks run without problems
The following contributions have also been considered.
https://knowledge.autodesk.com/de/support/formit/troubleshooting/caas/sfdcarticles/sfdcarticles/DEU/...
https://knowledge.autodesk.com/de/support/formit-pro/learn-explore/caas/sfdcarticles/sfdcarticles/DE...
