FormIt AXM file have problem with plan region
rawezh
Message 1 of 10
rawezh
Hi everyone, when I make FormIt file inside revit file and I need (plan region) to show elements that above default view (cut plane) , (enable cutting in views) for FormIt model not work in plan views, is there a way to solve it? see attached images.
Replies (9)
Message 2 of 10
kimberly_fuhrman-jones
Moved from Revit Ideas for support.
Kimberly Fuhrman-Jones
Revit Community Manager
Message 3 of 10
@rawezh What version of Revit are you using?
Message 4 of 10
rawezh
Revit 2024
Message 5 of 10
lucdoucet_msdl
@rawezh
As the FormIt AXM file is an imported CAD family in Revit 2024, have you enabled the "Enable Cutting in View" instance parameter of the imported model?
More information here: CAD Linking/Importing File Support (What's New in 2023)
Sorry, didn't realise you mentioned having enabled this in your message.
Are you saying in the screen capture that the "enable cutting in view" is not working for the front windows as well as the plane region in the rear?
Would you mind sharing the AXM model for me to test it independently?
-luc
Message 6 of 10
lucdoucet_msdl
@rawezh
I've tested the problem with a sample FormIt and Revit 2024 project and can confirm that the addition of a plan region to a Revit plan view doesn't seem to work.
My test also shows the effect on CAD linking a DWG, SAT and revit families version simultaneously. Here are some screen captures of this sample building:
Linked files with no plan region, the windows and door on the bottom elevation showing as expected when the cut in view parameter is selected.
The effect of adding an overlapping plan region has different effects depending on the source geometry:
 The Revit Families and DWG link work as expected, with the AXM link showing an un-cut version (without the roof!) and the SAT link disappearing all together!
When the plan region is moved off the geometry:
 The SAT link returns but the AXM link stays the same.
-luc
Message 7 of 10
lucdoucet_msdl
@rawezh
A temporary workaround would therefore be to export your AXM to a DWG, and link that file origin to origin.
The plan region seems to work fine with that format.
Hope this helps,
-luc
Message 8 of 10
rawezh
thanks for your hard work to test it, I hope in future this bug will be fixed for formit links, thanks again
Message 9 of 10
lucdoucet_msdl
I am unable to find the conversation thread in the Revit Ideas forum, searching for key words such as "plan region", "FormIt" aren't able to locate it nor does it seem to be associated to your user name.
Could you post a link to the ideas thread to facilitate upvoting be people who have found this thread?
Thank you,
-luc
Message 10 of 10
@lucdoucet_msdl  This thread was moved from Revit Ideas as a support issue.
