Faces appear wireframe only
aaronwagner
Message 1 of 13
aaronwagner
When modeling in FormIt 360, no matter if I'm using primitives or sketches, no objects will appear with solid faces.  Even applying materials will not help make the faces solid.
Wireframe - no hidden line
Aaron Wagner | Technology Consultant – Autodesk Construction Business Line Lead
U.S. CAD | Achieve More
Rocky Mountain Region, Denver, CO
T: 877-648-7223 x301
Replies (12)
Message 2 of 13
tvollaro
Aaron,
Sorry you are having graphics issues with FormIt 360. Does this happen all of the time, or intermittently? Can you please send us your version of Chrome and graphics cards specs?
Tom Vollaro
Experience Design Architect - Autodesk
Message 3 of 13
Tobias_Hathorn
Agreed - it would be very helpful to know your graphics card spec. Also if the same bug happens in Firefox as in your chrome browser. Thanks for posting about the issue!
Message 4 of 13
aaronwagner
Thanks for responding, guys!  I'm away from that computer at the moment but I'll get that info to you ASAP.
Message 5 of 13
Tobias_Hathorn
Whenever you get a chance to revisit this... Here's the type of info we need to debug this graphics issue:
  • Start the browser, start a new tab
  • Open the Debug console (F12 on Chrome)
  • Navigate to the FormIt app – the app loads – the empty scene appears
  • Place a cube – it looks wrong
  • Click the ‘console’ tab in the developer tools
  • Click in the output and Ctrl + C, then Ctrl + V into an email (forum post, or direct message to me)
here's a short video showing me walking through these steps - attached.
Thanks for the help!
Tobias
[video]
Message 6 of 13
aaronwagner
Ok here goes (I'm pasting here for future user lookup sake):
?parentHostname=formit360.autodesk.com:279 loading....
?parentHostname=formit360.autodesk.com:159 Downloading data... (32768/17719600)
?parentHostname=formit360.autodesk.com:160 Module.setStatus Downloading data... (32768/17719600)
?parentHostname=formit360.autodesk.com:159 Downloading data... (17719600/17719600)
?parentHostname=formit360.autodesk.com:160 Module.setStatus Downloading data... (17719600/17719600)
?parentHostname=formit360.autodesk.com:159 Running...
?parentHostname=formit360.autodesk.com:160 Module.setStatus Running...
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Depth textures enabled.
SimpleGlue.js?v=1151021446502121877:27 resizing 300x150 to 394x851
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 pre-main prep time: 3271 ms
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Supported OpenGL ES extensions <ANGLE_instanced_arrays GL_ANGLE_instanced_arrays EXT_blend_minmax GL_EXT_blend_minmax EXT_frag_depth GL_EXT_frag_depth EXT_shader_texture_lod GL_EXT_shader_texture_lod EXT_texture_filter_anisotropic GL_EXT_texture_filter_anisotropic WEBKIT_EXT_texture_filter_anisotropic GL_WEBKIT_EXT_texture_filter_anisotropic OES_element_index_uint GL_OES_element_index_uint OES_standard_derivatives GL_OES_standard_derivatives OES_texture_float GL_OES_texture_float OES_texture_float_linear GL_OES_texture_float_linear OES_texture_half_float GL_OES_texture_half_float OES_texture_half_float_linear GL_OES_texture_half_float_linear OES_vertex_array_object GL_OES_vertex_array_object WEBGL_compressed_texture_s3tc GL_WEBGL_compressed_texture_s3tc WEBKIT_WEBGL_compressed_texture_s3tc GL_WEBKIT_WEBGL_compressed_texture_s3tc WEBGL_debug_renderer_info GL_WEBGL_debug_renderer_info WEBGL_debug_shaders GL_WEBGL_debug_shaders WEBGL_depth_texture GL_WEBGL_depth_texture WEBKIT_WEBGL_depth_texture GL_WEBKIT_WEBGL_depth_texture WEBGL_lose_context GL_WEBGL_lose_context WEBKIT_WEBGL_lose_context GL_WEBKIT_WEBGL_lose_context>
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: GL vendor <WebKit>, renderer <WebKit WebGL>, version <WebGL 1.0 (OpenGL ES 2.0 Chromium)>
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Is OpenGL ES 2.0
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Framebuffer objects are not supported
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Framebuffers with 24-bit depth buffers are not supported
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Framebuffers with 8-bit stencil buffers are not supported
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Framebuffers with packed 24/8 depth/stencil buffers are not supported
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Non-power-of-two textures are not supported
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Repeat wrapping modes for non-power-of-two textures are not supported
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Mipmapping for non-power-of-two textures is not supported
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Depth texture is not supported
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: Maximum texture size is 8192
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: fragment highp: 127 to 127 @Anonymous
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: fragment mediump: 127 to 127 @Anonymous
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: fragment lowp: 127 to 127 @Anonymous
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: vertex highp: 127 to 127 @Anonymous
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: vertex mediump: 127 to 127 @Anonymous
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: OpenGLES::RenderCapabilities: vertex lowp: 127 to 127 @Anonymous
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: Error linking shader program
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: Link error information:
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 info firefly: C:\fakepath(63,12): error X6077: texld/texldb/texldp/dsx/dsy instructions with r# as source cannot be used inside dynamic conditional 'if' blocks, dynamic conditional subroutine calls, or loop/rep with break*.
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Warning: D3D shader compilation failed with default flags.
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Retrying with avoid flow control
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 C:\fakepath(63,12): error X6077: texld/texldb/texldp/dsx/dsy instructions with r# as source cannot be used inside dynamic conditional 'if' blocks, dynamic conditional subroutine calls, or loop/rep with break*.
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Warning: D3D shader compilation failed with avoid flow control flags.
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Retrying with prefer flow control
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Warning: D3D shader compilation failed with prefer flow control flags.
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Failed to create D3D shaders.
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_cubeMatrix
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_mvpMatrix
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_normalMatrix
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_lightDir
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_camera
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_ambient
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_color
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_enableTexture
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_enableNormalMap
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_enableOpacityMap
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_enableLight
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_isShowFaceSides
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_scale
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_isMirrored
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_reflectionFactors
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_isAmbient
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_fogRange
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_fogColor
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_fogDensity
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_bLinearFog
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_bFog
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_stippleEnabled
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_stippleColor
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_stippleSize
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_stippleOffset
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_texture0
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_normalMap
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_reflectionMap
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Missing uniform variable u_opacityMap
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 WebGL: INVALID_VALUE: getAttribLocation: no object or object deleted
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 WebGL: INVALID_VALUE: vertexAttribPointer: index out of range
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 WebGL: INVALID_VALUE: enableVertexAttribArray: index out of range
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 WebGL: INVALID_VALUE: disableVertexAttribArray: index out of range
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 ESTextureLoader Anisotropy Enabled? 1
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 ESTextureLoader Max Anisotropy? 16
formit.js?v=1151021446502121877:15298 Object {user: Object, success: true}
util.js:30 SensorNotRequired: https://developers.google.com/maps/documentation/javascript/error-messages
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Enabling service "Autodesk FormIt Pro".
formit.js?v=1151021446502121877:5911 started click on tool
formit.js?v=1151021446502121877:5915 ended click on tool
blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 WebGL: too many errors, no more errors will be reported to the console for this context.
formit.js?v=1151021446502121877:3722 SELECTED PROPERTIES Object {showObjectProperties: true, showFaceProperties: false, showImageProperties: false, showEdgeProperties: false, showInstanceProperties: false…}
SimpleGlue.js?v=1151021446502121877:27 resizing 394x851 to 1362x928
2blob:http%3A//app.autodeskformit.com/59ad6545-b312-4d3f-93a7-4eefc88f382a:1 Enabling service "Autodesk FormIt Pro".
Message 7 of 13
aaronwagner
Here's a bit from the script console output in case it's helpful:
Object {showObjectProperties: false, showFaceProperties: false, showImageProperties: false, showEdgeProperties: false, showInstanceProperties: false…}
allowOtherCategories: false
alpha: 0
area: "0 sq ft"
canBeMassCategory: false
imageId: 0
isCalculatingAreaByLevel: false
isGeneratedFromBuiltinRFA: false
isGeneratedFromRFA: false
isOnMultipleLayers: false
isSatelliteImage: false
layerId: -1
length: "0'"
numInstancesSelected: 0
numObjectsSelected: 1
revitFamilyCategory: ""
revitFamilyExtraData&colon; ""
revitFamilyReference: ""
revitFamilyType: ""
showGroupProperties: false
showLayerProperties: true
showLevels: 1
volume: "1728 cu ft"
__proto__: Object
__defineGetter__: __defineGetter__()
__defineSetter__: __defineSetter__()
__lookupGetter__: __lookupGetter__()
__lookupSetter__: __lookupSetter__()
constructor: Object()
hasOwnProperty: hasOwnProperty()
isPrototypeOf: isPrototypeOf()
propertyIsEnumerable: propertyIsEnumerable()
toLocaleString: toLocaleString()
toString: toString()
valueOf: valueOf()
get __proto__: get __proto__()
set __proto__: set __proto__()
Message 8 of 13
aaronwagner
Also re: previous inquiries, Chrome is on latest version with updated graphics drivers installed.
Message 9 of 13
Tobias_Hathorn
Thank you Aaron!!! This is exactly what we needed! We'll work on a bug fix and then get in touch with you to see about testing it out on your specific graphics card!
Tobias
Message 10 of 13
aaronwagner
Quick update:
My computer has the ability to switch graphics cards for various reasons.  Originally, I was using:
Intel HD Graphics 4000 (Integrated)
For kicks, I switched to the other card:
NVIDIA GeForce GTX 675M
And I'm happy to report I'm now seeing proper solids.
Message 11 of 13
Tobias_Hathorn
Great news! Thanks so much for the update.
Message 12 of 13
Tobias_Hathorn
Hi Aaron - Just wanted to follow up and see if you were still seeing the graphics issues on your integrated card?
We published a fix a bit ago - but not sure if this will help in your case.
Also can you make sure you're running the latest version of your browser?
Thanks for your assistance!
Tobias
Message 13 of 13
D.Sanchez
Hi Tobias,
To be honest, I haven't had much chance to experiment with it.  I tested it now and everything looks great, behaving as expected.
Thank you!
Aaron
