FormIt Forum
Welcome to Autodesk’s FormIt Forums. Share your knowledge, ask questions, and explore popular FormIt topics.
Drawing Effectively In FormIt
1 REPLY 1
634 Views, 1 Reply
My query is summarised in the attached screenshot. In summary, When I draw geometry that overlaps with the edge of a face, the two geometries are merged. Because they're merged, I can't then move one geometry without affecting the other. I would still like the two geometries to act independently though.
1 REPLY 1
Tobias_Hathorn
You have to work with Groups to keep geometry isolated from other geometry. So after 'finishing' the first shape - double click it to select the full set of geometry (edges + faces). Then right click to bring up the context menu and choose the Group command. You can also use the keyboard shortcut 'G' when you have elements in selection.
At this point you can single click a group to select it - then you can move  - or otherwise adjust it.
To edit the geometry once it is grouped you can double click to enter edit group mode.
I hope this helps!
Tobias
