Starting a New Project
aigence_bimtenders
aigence_bimtenders
Community Visitor
Community Visitor
I am trying to experiment Forma Pre-Construction Design.
I took the following steps :
Created an Autodesk Account > Initiated a 30 days free Forma Trial > Started Forma for Site Design > Landing on the attached page....
But unable to start any new project...Tabs are all greyed out.
Please advise
kevin_vong1
The greyed-out tabs mean your Forma license isn't yet connected to a Hub — every project and site in Forma Site Design has to live inside a Hub, and each company works out of one shared Hub. Normally, the first person from a company to open Forma Site Design with an unconnected license is prompted to create that Hub. If you don't see that create-Hub prompt, it usually means someone else at your company has already set one up, and you'd need to ask them (or that Hub's admin) to invite you, or send a request from within Forma for them to approve. Full details and screenshots for each scenario are here: https://help.autodeskforma.com/en/articles/7878583-setting-up-the-hub-for-your-company
If this answered your question, please consider marking it as the solution. It helps others with the same limitation find the answer more easily.
Best,
Forma Design
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Kevin Vong
Product Support Specialist
