Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Wind detailed analysis always failed
7 REPLIES 7
Message 1 of 8
ThitipatP
782 Views, 7 Replies
ThitipatP
I tested some model on wind analysis. I got only result in rapid mode. But when I click the run detailed analysis, It's always failed. Any suggestion please.
Labels (1)
7 REPLIES 7
Message 2 of 8
per.wessel.noreCT6K6
Hi!
Can you provide me with the link to the proposal that failed the analysis? If so we can take a look and see what happened.
Kind regards, Per
Hi!
Kind regards, Per
Message 3 of 8
thitipattpcad
in reply to: ThitipatP
Message 4 of 8
Thank you for the link.
The wind analysis is failing because the terrain is too steep. This usually happens if the terrain is too steep at the edge of the wind tunnel, or the overall difference in altitude across the whole tunnel is too large. The size of the wind tunnel is 1000m*1000m with a center at the center of the wind circle. You can see if you can smoothen or flatten terrain in the steep areas within that boundary to try to get a running wind analysis.
Kind regards, Per
Kind regards, Per
Message 5 of 8
thitipattpcad
thitipattpcad
Hi
Thank you for your reply. I change the terrain to flat version and reduce the analysis area and it's work fine now.
Hi
Message 6 of 8
AntonioCampanario
Hi Per,
what to do when the terrain is not to steep (like our country the netherlands) but the wind analysis keep failing?
Somehow multiple attempts failed but can not figur out why.
just started a new attempt 🤞 ...
Ran/Run analysis:
sunhours, succesfull
daylight, succesfull
wind, failed & running new... and once again failed
microclimate, succesfull
operational, no need
noise, no need
Hi Per,
Ran/Run analysis:
noise, no need
Message 7 of 8
AntonioCampanario
"weekly update"
Update 26-9:
original project with combined data since 19-9-2023
re-created a simplified version of the project with openstreet map data only
re-created a simplified version of the project with NL data only
Unknown cause of failures...
"weekly update"
Update 26-9:
Message 8 of 8
ThitipatP
Thank you, I'll try as mentioned.
